mneblett
#32806
I'm searching for what seems to be a unicorn. I have an R1250RT with the stock cast upper triple clamp (in BMW speak, "upper fork cross brace").
I'm working on a project to move the grips closer to me than I can achieve with the grip risers such as those from Ilium Works and Helibars. I will be experimenting with swapping in the upper triple clamp for tubular handlebars and working with a set of Heilbar's K16GTL Horizon bars (the ones with several degrees of freedom). There may be some wiring/hose extensions needed, but that is within my skill set.
Here's the rub: The stock BMW tubular handlebar (and hence the saddles of the triple clamp they sit in) are 32 mm diameter in the center section, and the K16 Helibar kit has a 1" (25 mm) center section bar diameter. I've been searching, so far without luck, for a bar riser or bar back that will: (i) bolt up to the BMW tubular bar upper triple clamp; and (ii) present a 1" (25 mm) saddle to receive the Helibar K16 center section tube.*
Please let me know if you have any suggestions!
* Ultimately, I can use my mill to create a set of risers to meet my needs, and I may ultimately have to do so. But I can save myself a lot of work if I can simply buy a pre-made set.
Thanks!
Thanks!
