2018 R12 GS with sidecar and automotive rim and tire on the rear. TPMS reads 3.5 to 4 psi low. Problem is I should have 30 to 32 psi, but to avoid Low Tire Warning I need to have 35 to 36 psi actual. Everyone I ask says the setpoint can not be changed. Is there any way to disable the warning for the rear tire only? Alternatively is there a sensor which reads 4 or 5 psi higher than actual?
Center of tread is wearing. See photo after 6200 niles.
