Just so you know, the left wire is blue with a red trace and goes to the reflector assembly post that touches the center of the bulb. The whole thing grounds out through the aluminum housing and through the forks. The right wire is blue with a black trace.
Both wires in this harness go to the terminal junction block inside the headlight. There are four wires at each terminal. One to the front signal, one to the rear signal, one to one side of the indicator light and one to the t/s switch.
