2002 K1200RS High Idle
mehrten
Mehrten
Our 2002 K12RS (ZG35448) began to idle high, 1,500+ rpms, several years back. My first thought was an air leak as the breather hose from the engine to the throttle bodies was cracked and leaking oil on to the engine and leaking extra air into the throttle bodies. I replaced it with no problems. Idle remained high.
Using a GS-911 I set the TPS and verified the throttle arm was working correctly. I tested the lines from the temperature sensor to the ICU and found no obstructions or loss in continuity. The fans come on about the time the water temperature hits just above halfway as they should.
Iron Horse Motorcycles in conjunction with Bee Mer Works found an o ring under one of the throttle bodies leaking. They replaced the leaking one, I replaced the other three. Slight change, then back to high idle.
Spraying a quick-start spray around the throttle bodies or the breather hose does not cause any change in the engine idle.
A known working ICU was swapped in and out. No change.
Used known good TPS and throttle arm pieces were swapped in and out. No change.
Early on I replaced the battery. No change.
I pulled the fuel pump out and found the screen was rotted away. The fuel filter was old. I replaced the entire assembly, fuel filter, pump, hoses, etc., with an EME pump. Cleaned the gas tank, fresh gas. No change.
I’ve pulled the wiring/relay cover off and fiddled with the massive collection of wires. I didn’t find anything loose or disconnected. No change.
I started the engine, let it idle until the fans came on. I shut down the engine and unplugged the ABS module. I restarted the engine; let it idle for a bit…still high.
I started the engine and let it idle until the fans came on. Then I shut down the engine and pulled out fuse 1. Started the engine…no change…high idle. I did that with each fuse. No change.
No matter what I’ve done, when the engine starts the throttle arm actuator pushes the idle up to about 1,500 rpms.
At that RPM across the battery terminals, it shows 14.2 volts. Iron Horse tested the regulator and found it functioning properly.
Note: Each time I disconnected the battery, I did the three throttle twists before restarting.
Next step? Starter relay problem? Problem with handlebar switch(s)? Bad plug connection?
Suggestions?
Deryle Mehrten
Sierra Vista, Az USA
My guess: Your ICU thinks the bike is still cold or lean so it’s engaging the high idle setting. Since you’ve swapped the ICU without affecting the issue, I don’t think the problem is in the ICU. And, your checks on the mechanical linkages/settings and air/fuel plumbing pretty much rule out issues there.
That leaves the engine temp sensor—not the one that controls the temp gauge, but the one that speaks directly to the ICU. Either a bad sensor, or a bad connection, but the fact the ICU is engaging the fans after the bike warms is a contraindication—so I wouldn’t immediately fire the parts cannon without first checking the wiring to that sensor, and taking some cold/hot readings on its output. Normal failure mode on that sensor is for the bike to start running richer and richer to the point where it floods out and dies when the bike reaches normal operating temp- but will restart happily once cooled down.
Anyway, I’d poke around at that sensor and see what it tells you. #15 in this diagram, and come to think of it—I think this is the only temp sensor used on the later brick-k bikes.
Best,
DeVern
EDIT: And as long as you’re checking sensors, it wouldn’t hurt to check the O2 sensor as well.
Devern,
As you said, strange that the brain seems to be getting a "I'm not warm yet signal" though the fans still turn on.
I'll play around with the temp sensor again.
Thought...
When the starter button is pressed isn't there an enrichment process that assists starting? Just because I can I'll pull the right handlebar apart and clean everything.
Does the starter relay have anything to do with the enrichment process?
I'll get back to the list in a couple of days.
Appreciate the help.
Deryle Mehrten
Sierra Vista, AZ USA
Remember that it is the amount of air that controls engine speed, not the amount of fuel. Too much or too little fuel will make the engine combustion too rich or too lean but would not generally cause increased RPM.
Added: If a mixture is too rich or too lean idle speed may drop and restoring proper mixture might return idle speed to normal, but mixture ought not cause an abnormal high idle speed.
“Used known good TPS and throttle arm pieces were swapped in and out. No change.”
Does that mean both the throttle actuator and throttle valve switch (TPS) were swapped out with known good units? If so, was the TPS setting checked with the test unit?
Best,
DeVern
Guys,
I just did a 2000 ohm test on my "spare" oil temperature sensor.
At aprox. 100 degrees f (the temperature inside my backyard shop) the ohm reading is 1.500 or so.
Using a heat gun, the resistance began dropping immediately and at 125~150 the ohm reading was below 1.0 and continued to fall.
I believe the "spare" sensor is working correctly. What do you think?
Tomorrow I'll do a check of the wires from the sensor connector to the brain; and I'll connect the spare sensor and heat it with a heat gun and see what the idle does.
The "spare" tps and tva were sourced from Beemer Boneyard. They came mounted to a complete throttle body,
Each time the tps or tva were "messed" with, either myself or Iron Horse re-set the tps. Not much you can do with the tva. Per my GS-911 the tps is within range.
Tomorrow...
Deryle Mehrten
If you can see and have easy access to the temperature sensor, check it on the bike. Cold water from a hose, heat from a heat gun.
Gentlemen,
I just finished tracing and testing the two wires from the oil temperature sensor plug to the ICU.
Before I did any probing, I removed the battery and removed the ICU.
Both wires have no resistance from the plug to the corresponding pins on the ICU, pins 7 and 22. No connectivity problem there.
Next, I'll do the same for the tva and the tps. Time for a lunch break.
Deryle Mehrten
OK, braved the heat...
I tested the tva (Throttle actuator) with no issues with the wires from the plug to the ICU (Motronic control unit), pins 22, 28, 27 and 29.
The Air temperature sensor tested with no issues as well, pins 6 and 22.
Getting the connector off the tps (Throttle potentiometer) is too difficult without removing/loosening the throttle bodies. I'll see what the GS-911 says. Seems to me it was OK, but I will test again.
So far, no issues found.
I did test the temperature sensor in the engine by directing my heat gun at it. It immediately began going down just like the "spare" one.
Rotti started right up and of course the idle was high as expected. I did not let her idle that long, just made sure I connected everything back up right. Tomorrow I give her a full test.
Any other suggestions?
Ride safe...
Deryle Mehrten
  • Like
Reactions: lee
