Our 2002 K12RS (ZG35448) began to idle high, 1,500+ rpms, several years back. My first thought was an air leak as the breather hose from the engine to the throttle bodies was cracked and leaking oil on to the engine and leaking extra air into the throttle bodies. I replaced it with no problems. Idle remained high.
Using a GS-911 I set the TPS and verified the throttle arm was working correctly. I tested the lines from the temperature sensor to the ICU and found no obstructions or loss in continuity. The fans come on about the time the water temperature hits just above halfway as they should.
Iron Horse Motorcycles in conjunction with Bee Mer Works found an o ring under one of the throttle bodies leaking. They replaced the leaking one, I replaced the other three. Slight change, then back to high idle.
Spraying a quick-start spray around the throttle bodies or the breather hose does not cause any change in the engine idle.
A known working ICU was swapped in and out. No change.
Used known good TPS and throttle arm pieces were swapped in and out. No change.
Early on I replaced the battery. No change.
I pulled the fuel pump out and found the screen was rotted away. The fuel filter was old. I replaced the entire assembly, fuel filter, pump, hoses, etc., with an EME pump. Cleaned the gas tank, fresh gas. No change.
I’ve pulled the wiring/relay cover off and fiddled with the massive collection of wires. I didn’t find anything loose or disconnected. No change.
I started the engine, let it idle until the fans came on. I shut down the engine and unplugged the ABS module. I restarted the engine; let it idle for a bit…still high.
I started the engine and let it idle until the fans came on. Then I shut down the engine and pulled out fuse 1. Started the engine…no change…high idle. I did that with each fuse. No change.
No matter what I’ve done, when the engine starts the throttle arm actuator pushes the idle up to about 1,500 rpms.
At that RPM across the battery terminals, it shows 14.2 volts. Iron Horse tested the regulator and found it functioning properly.
Note: Each time I disconnected the battery, I did the three throttle twists before restarting.
Next step? Starter relay problem? Problem with handlebar switch(s)? Bad plug connection?
Suggestions?
Deryle Mehrten
Sierra Vista, Az USA
Suggestions?
Deryle Mehrten
