bp@sr9
#81822
Boy, this is a courtesy that is missed all too regular.
for bringing it up.
yeah, my rim was at the powder coaters-for awhile. thought a sec 'bout gettin'
loud, took some blueberry cake donuts instead -done next day!
for bringing it up.
RJLJR, Debugging this kind of problem can be very hard. If it were my bike (understand the bonding thing) I would wire three LEDs (ones with resistors so you can connect them to 12V) to the following spots:
#1 +12V input to the Motronic and Fuel Pump Relay control coils (it's a green/yellow) wire
#2 Output of the Fuel Pump relay contact
#3 Output of the Motronic relay contact
Line the LEDs up in a row somewhere where you can glance down and see them.
With key off, all LEDs should be off.
With key on, bike not running, Motronic should be on. Fuel pump should come on for two seconds.
With bike running, all LEDs s should be on.
Then when you're riding, if you get a cut out, immediately look to see which LED has gone out.
RB
Failed on the way home from work. Rolled to the side of the road.
Wouldn't start.
I cycled through on/off on ignition, kill switch, side stand up and down.
............. later .................
While sitting at a light, kaput, stopped. RID still up, all lights normal, would turn over, could hear fuel pump kicking in....nothing.
Side stand up/down. No change though I did notice that when the stand goes down, the RID goes off, comes back up when the stand comes up. (RID off with side stand down is NORMAL. )
Won't fire up.
Was giving up and decided to hit it one more time. Started.
As I was about to pull out, stalled, again.
Hit the starter, started.
.............. more stuff .............
"Befuddled"
Wouldn't start.
Gave her another go and presto.
Started.
Cut short my joy ride home from work. Got it in the garage, jiggled wires to see if I could get it to fail. Nope.
Geez....square 1, again?
This morning:
Decided to take it to work this morning so that if it happened again I could be more systematic in the process of getting it re-started.
Started right up. Got to work and realized that I forgot my work phone so I started it back up and headed off. While sitting at a light, kaput, stopped. RID still up, all lights normal, would turn over, could hear fuel pump kicking in....nothing.
Pushed it off the road to a parking lot and since I DIDN'T have the phone, was hoping that someone coming in to work would pass and save me.
Meanwhile, started through the cycle.
Kill switch on/off. No change.
Ignition switch on/off. No change.
Won't fire up.
Decided to shoot for work since it was closer than home. Shot to work, one little cough but made it all the way. Put it on center stand running, jiggled and jiggled and jiggled. Won't fail!!??
