roger 04 rt
I finally heard back from the BMW Dealership.
They tell me that they had the bike apart, checked ALL their work that might have "jiggled" anything loose,as well as checked grounds, wiring, etc, where accessible and.....nada.
We are back where we started from.
I believe that I will pick the bike up, have someone follow me back (@ 80 miles) with a trailer, just in case, and......wait for it to happen - again (or not!?).
If (when) it does, I guess it will be a garaged winter of wiring harness exploratory or for sale sign!!
Missed a great summer on this bike. I have a fall back ride (Yamaha - Cruise) but...only good for milk runs.
If there is anyone with anything do add, please do!
Much obliged.
RJLJR
RJLJR, Debugging this kind of problem can be very hard. If it were my bike (understand the bonding thing) I would wire three LEDs (ones with resistors so you can connect them to 12V) to the following spots:
#1 +12V input to the Motronic and Fuel Pump Relay control coils (it's a green/yellow) wire
#2 Output of the Fuel Pump relay contact
#3 Output of the Motronic relay contact
Line the LEDs up in a row somewhere where you can glance down and see them.
With key off, all LEDs should be off.
With key on, bike not running, Motronic should be on. Fuel pump should come on for two seconds.
With bike running, all LEDs s should be on.
Then when you're riding, if you get a cut out, immediately look to see which LED has gone out.
RB
