On the ignition switch, is there a cleaner and lube you can spray into the switch, from the key insert opening, that would displace any water and lube the switch? On the start button and kill switch, right handlebar, if I open the switch up, can I spray a electronic cleaner on the contacts?
Any thoughts or recommendations. Thanks, oldcarman Jim
