When I had my shop I always replaced the oil filters with new ones just as an assurance for my customers. I'm personally using filters from a stock that I bought about ten years ago. Some of them are the really, really old style that use the separate O ring on each end. This particular engine, in my /5, has well over 40,000 miles on it! Last winter I renewed the pushrod tube seals and inspected the bottom end and cylinders. Even pulled the oil pan to check on the pick-up screen bolts. Everything looked to be in excellent condition. The old filters, when changed have been inspected and show no signs of falling apart or disintegrating into the oil system.
I have seen some of the newer filters with the O-ring installed, where the outer ring is cracked; but I don't have a proof positive explanation as to why the cracking occurs.
Snowbum agrees with you on his page:
http://bmwmotorcycletech.info/torquevalues.htm
He says 15-20 ft-lbs.
OOPS. I may have forgotten to mention that these springs are shorter than the standard springs and made from a heavier gauge wire. You don't need a spacer on a bare bike but may use one if you're running a heavy (Vetter, Luftmeister, Rabid Transit) or such fairing.
Chris,
Cool beans. I believe your will find a write-up showing all the parts, in order, for the throw-out lever assembly.
Best of success in keeping you '72 on the road.
Best.
Brook.
Thanks for the encoragement Brook. Both the seal and the boot were junk. Replacement went as easily as you said and I haven’t seen a drop of oil since.
As I understand it, they're pretty tough to install...I had my dealer do it.
check!my /5 doesn't fall into that category in the least. It's a rider! So my preference is to have modern tires.
check!i've been very happy with the bridgestone spitfires and yes, i know that they're not made in the "original" sizes of 3.25x19 and 4.00x18.
check!they work for me, stick very well wet or dry, and last a long time.
