tangoalpha
Member
My Fellow Oilheads,
Well....the work on Der Beemer continues. If you happen to have read my previous thread about replacing the battery on my bike, this is somewhat of an update. The battery install went fine, but as mentioned in the last post, once I got the bike back together, before starting I attempted to recalibrate the Motronic FI. I did this by turning the ignition on, twisting the throttle (WOT) and releasing, 2X. Then I started the engine. I noticed a rough idle that wasn't there before so I sought the advice of forum members and was encouraged to check the throttle cable to ensure that they didn't pop out of the ferrels attached to the throttle body on the left & right side of the bike. So on that suggestion, I took the panels off again and double checked the throttle cables. Everything appeared to be fine. The cables were seated in the ferrels and the cable didn't hang up on anything. The rough idle is still a mystery. I'm open to your thoughts on what else I can do to correct this. Throttle body sync comes to mind, but again, this was all brought on by changing my battery. So that makes this rough idle that much more baffling. I'm considering installing an AF-Xied. Any of you with experience with this product have any feedback on that? Also, what about installation? I understand that since my bike is a 2002, the AF-Xied unit for my bike is a matter of plug and play. From what I understand the O2 connector is under the gas tank on the right hand side of the frame. Would I need to remove the gas tank entirely or can I simply prop the tank up to access the plug?
Since I had already removed the left/right panels and belly pan, I decided to remove the nose cone/headlight assembly to fix the headlight adjuster that doesn't work. Turning the dial on the dash right or left does nothing to raise or lower the headlight beam. I also wanted to remove my inner fairing to install a new TPMS system I ordered. Figured since I had the bike apart anyway, I might as well just remove the inner fairing since it was only a few screws and would be much easier to work on than actually mounted to the bike itself. I am a bit stumped on how to remove the headlight adjuster from the inner fairing or the cable which attaches to the headlight assembly. Any tips? See pics.
Lastly, I've started my 24K service. I've replaced my air filter, engine and well...now a new battery. Next on the to do list is changing changing the brake and clutch fluid (something I'm dreading the thought of on this servo equipped bike), change the gear box fluid, change the final drive unit which appears to be a pice of cake. I know that there are special crush washers (and NM torque specs). Would someone happen to know the part numbers? Then finally I need to finish up by replacing the spark plugs and the fuel filter. I know the fuel filter is gonna be a PITA, so any tips on that would be wonderful.
