Cycl2day
Cycl2day
If you are looking to upgrade both tail/brake lights the Denali system is very good and easy to install.
I added the Denali D4 aux lights last year and just purchased & installed the sound bomb horn and brake lights with the camsmart harness. I first had to remove the lighting harness that came with the D4's and replace it with the camsmart harness. It's easy to do, requiring removal of some of the plastic around the tank and not much more.
The horn is mega loud and the brake lights bright and able to be programmed in several ways. I can now dim the D4's as well which was not possible before now. I think the Denali system is very good and worth a look!!
2013 1200GS
2013 1200GS
