RBEmerson
Kein Nasebohrer
After a week on a KGT in the Alps (Munich area, Andermatt area, Southern Tirol / Alto Adige area, Dolomites / Grossglöckner area), not too surprisingly, I learned a lot.
What follows may appear to be trolling - it is not!
In the open, "merely" curvy mountain roads, the bike did quite well. Ditto for the Swiss, Austrian, and Italian autobahns / autostrada (130 km/h / 80 mph tops). The really high speed excursion on the German autobahn system was cut short by a series of traffic jams. But take the bike to the passes and... not so good.
The hairpin turns (called Kehern in German, Tornanti in Italian) in the pass roads are, by definition, 150° or more turns. The width of the internal medial strip can vary between maybe 50-60 feet to 5-10 feet. The grade of the roads approaching and leaving the turn typically range between a very modest 7% to 12-14% (one non-pass road hits 16%).
The KGT simply doesn't have the gearing or low speed torque to do much more than get through a turn. The larger radius turns can be ridden as counter-steering turns in first or second gear. The tighter turns have to be handled as steering turns. In those instances, my weight went to the outside of the turn, to get the bike on the side of the tread. That makes steering the turn much easier than standing up and using the center of the tire. The KGT didn't really resist the turns, but it wasn't in a mood to really help, either.
The really part is first gear is required and the engine speed in the turn can drop to 1500-2000 RPM. There just isn't a lot of meat in the motor at what amounts to a high to very high idle. Top-heaviness adds to the challenge. On more than one turn I had to wind the throttle up early to get moving enough to avoid a drop.
One of the most challenging pass roads is the north road to the pass on Passo dello Stelvio or Stilfserjoch (2757 m or 9025 ft). There are 48 turns (each has a number at the outside apex) and they range from tight to very tight.
I saw maybe 5-6 other KGT's at the top, but I was able to talk to only one rider. My Russian is non-existent, and his English was strained. NTL I noticed sliding scrapes on the left pannier. I don't know where that happened, but it can't be a good sign.
I rode the same road on a '15 "wethead" RT last year. Although the RT's transmission acted and shifted as though it was on the way out, at least I could keep the motor above 3000, and typically went through the turns at 4000+ - lots of torque available.
The take-away: for anyone thinking about renting or taking their KGT to the Alps, think more than twice about "pass hunting". This just isn't the bike to do that on.
I shot 400G+ of video(!) on the week's trip. I hope to have the first installment up this weekend. It covers the main Leutasch valley road, which is a very easy ride. Unless you meet a "Post bus" (public transportation system) on a tight road... I'll post the YouTube link here.
