tinytrains
Still plays with trains.
So has anyone done a valve adjustment yet?
Is it the same as the Cam-Head?
Just curious.
Just curious.
Is there an engineering justification for moving from threaded adjuster, to semisphere, to a differently-shaped shim, all for generally-similar 4-valve twins within a period of four years?
I imagine returning the cams to their proper position will be the next instruction needed. Other than that, it looks pretty straightforward. No chains to mess with, just align the gears.
Hey Jim, sorry about the lame question, but with 21 different choices of adjustment plate to purchase, how do you know which is the correct set to order? And by the way, I've ordered you DVD, which should make it to my home next week in Charleston, SC. In the meantime, I was curious how this small feat is accomplished. Since I must order the shims before I open everything up...you can see where i'm going with this. Thanks to anyone who can answer my question.
Harold you must first inspect and or measure the shim your bike came with. If the clearance is to tight usually going down 1 size will get you in spec. I would measure the clearance and calculate for the most accuracy.
So with the throttle-by-wire, am I correct in assuming the days of synchronizing throttle bodies are over, at least as far as wetheads go?
Harry
