Went to dealer to have my tires changed. I knew original brake pads were close to being worn out but dealer told me I would also need to replace all rhe disks. With 36k miles this seems a little premature. The disks are more than a thousand dollars and pads $250 from dealer. I'll probably buy some used disks but it seems like the only pads available are sintered or OEM organic. I don't want to wear out these disks any quicker. Are there any good after market organic brake pads available? What can happen if you run disks out of there wear limit? If they warp you could tell and then replace. Thanks
Sent from my SM-G970U using Tapatalk
