Scarletswirl
Member
My recently rebuilt '89 R100RT (42K miles) shows symptoms of uneven or warped dic rotors. Checked thickness with micrometer. Above 4 mm, but uneven. To compare, I checked my '95, with 20K original miles. 3.88 mm, but very uniform. Just as a reference, Haynes says the spec is 4 mm. I can't believe 20K miles is enough to wear out brake disc rotors, and it doesn't make sense that the '89, with double the miles has thicker rotors. Is anyone aware of any switch in the rotor thickness through the model years?
By the way, Snowbum says manufacturers tend to be too conservative with thickness specs and slightly undersized rotors should not be a problem. The '95 bike brakes fine, so I'm not overly concerned, just curious.
Second question, more important. Since the original rotors are near unobtainable and expensive, I went with EBC Pro Lite for the replacement and they just came in. Checked thickness, very uniform, but 5 mm instead of 4. Has anyone tried them? Does the added thickness cause problems, i.e. will it even fit in between the pads? I double checked and they are the right part numbers, but as I remember, the original ones were a tight squeeze already. Snowbum shows an EBC based conversion, but it doesn't use the original calipers, so the effect of the extra thickness is not discussed in the article.
Thanks to all,
Marc
Thanks to all,
Marc
