Another one of those rebuild stories R50/5
Piston went on without any trouble. I've heard horror stories about the cir clip being a huge PITA but three out of four went back in with hard pressure from my thumbs.
I'm having trouble getting that last ring compressed enough to slide the piston back in the jug. I've read on the interwebs that some have used the metal straps that hold the driveshaft boot on to compress the ring enough. My pistons are too small for that strap.
Suggests would be helpful oh wise MOA community.:dunno
I'm sure they make a large enough garden variety hose clamp that will do the same job. I recall reading that Duane Ausherman talked about a technique for using the fingers to squeeze the rings in while using the knee to slide the piston on. It's just necessary to get the ring to a minimum diameter so that the chamfer of the cylinder takes care of sliding it home.
Any base sealant on that? I think it's customary to use some even if you have the earlier type shims.
Thanks for the tip. My fingers just rant doing it for that last ring. My Clymer manual suggests a 'ring compression clamp.' Well isn't that nice, another special tool. I'll just have to check out the old hardware store for the garden variety clamp.
As for sealant I've got some Threebond to lightly smear in the engine casing.
Because of the year model of my /5 ('72) am I correct in thinking that not only was there not a big O-ring at the base of the jug but also an absence of the two top rubber gaskets that go at the base of the two top studs?
Any other suggestion about how to compress that final ring would be welcomed.
Here's a pic of tapered ring compressor. Looks like you've got the gapless 2nd ring and the three piece oil ring. Hard to finger those into the cylinder. Possible to jury rig something similar, but considering time and material, it's usually cheaper to buy or borrow. You're doing a great job.
I used my fingers to get that last ring through, it's a pain in the ass, but you can do it. I've heard of people using popsickle sticks to do the work in place of your fingers, but I've never had to go that route.
If you're feeling up to it, cut open a soda can and turn it into a sheet, take that sheet and wrap it around the piston, then take a large hose clamp (or you can even just use a wire tie to tighten the aluminum if it's all you have around) and compress that sheet over the piston rings- cheap, homemade ring compressor
If you want to buy a ring compressor they're not that much more complicated and are still fairly cheap
By the way I love this thread. This is what owning a vintage bike is all about - wrenching on it yourself, learning, and backyard engineering. I've told people that I've been inside my R90 so often it's now romantic. If anything ever happens to the bike on a ride, you'll know where to look and how to fix it on the side of the road, can't say that about a guy who just pays someone else to build him a clone bike
Try using the pointy ends of two chopsticks (one in each hand) to push the ring gap closed and push the cylinder in with your stomach.
Barron
Beer can + hose clamp = Appalachian Engineering. Got those rings tightened right up enough to get those pistons back home.
I knew I went to college for something.
Rockers back on to tighten everything up and push those pushrod tube seal in their holes.
Next up: valve adjustment.
I'm sort of intimidated by this idea so any words of wisdom, tricks of the trade, warnings, or general encouragement is welcome.
About the rockers...
The various shop books describe using an alignment jig. I don't have an alignment jig, and don't even see any around.
Is it needed, or does one just line those things up and bolt 'em on?
I've seen pictures of the jig...like a fancy "H". I would think that taking care and getting them aligned well should be sufficient. An important aspect is that the pushrod needs to move in and out such that it doesn't come close the walls of the tube. I believe it moves back and forth across the tube...you should be able to see the motion as you rotate the engine. Another aspect is that you have three parts with flat sides on them...the upper and lower pillow blocks and the rocker itself. So, it would seem important that these flat sides should be aligned parallel to each other as well as aligned in the same plane as the opposite rocker arm. Otherwise, you'll get binding and/or noise during operation.
Good call on that alignment. I found a page on-line that explains this process with the intent of changing the Push Rod Seals. Here's an image of that special H tool, that I don't own.
Is it possible for the layman to eyeball alignment keeping the push rods clear of the tubes without the special tool?
http://www.pbase.com/dqmohan/prtseals
I have no experience doing this, but Duane Ausherman has a procedure for using a large pair of channel lock pliers instead of the jig. It appears so at least.
IIRC, Duane's info is how to squeeze the pillow blocks together while tightening the rocker nuts...this minimizes the up-down movement of the rocker arm during operation. The red jig shown in the diagram is used for alignment in several directions to keep the rocker arms parallel and square to the head.
FWIW, Duane has this to say about BMW's rocker alignment tool, which looks identical to the red jig shown previously.
The factory supplied rocker arm alignment tool. It came in another version and both are completely worthless
Valve adjustment isn't too bad once you wrap your head around it.
It appeared the flywheel would make one complete revolution while one piston would complete three cycles. And when the OT mark would come back around again you had to pay attention to which piston is at TCD on the compression stroke.
These were my observations based only on the logic my brain came up with and I don't claim them to be scientific at all. If there is a better way of explaining it with more accuracy and/or clarity please post below.
So as you can see the headers are on. I bought them off eBay about three months ago. They are used but in vastly better condition than the originals. I've also installed a factory center stand. Also purchased months ago from one of you, fellow MOA members, along with a Brown's side stand. I don't like the look of the ride off center stand so it will be featured in the lot of all the other parts I'll be selling.
Question: Which way does the battery install? Positive on the left or right. Of all the things to not notice when pulling it apart......
