Prof. Robert
screwdriver
If you can't find a stethoscope, a large screwdriver works well.
Good Luck
Good Luck
Waehrik, in my post I should have said the tension rail could be broken. It is the plastic guide rail the tensoner activates to maintain tenson on the chain. I replaced a left rail last winter and could possibly help if you have to do the same job.
- removing the valve covers to check for broken cam chain guide rails.
I was thinking the buttons on the disc brakes could need replacing, but the clutch wouldn't have any effect on that.
Also, my R11RS ran smoother when I used Autolite 3923 spark plugs.
Good luck, I can't offer any suggestions, but I'm sure I'll learn following you as you fix it.
If you don't have any luck finding the RS intake tubes, let me know. I have a set setting somewhere on a shelf at home.
jerry.duke@gmail.com
