I understand that I need a coil puller tool before I put a socket on the plug. When it's inserted, how do I know it is seated onto the coil before pulling? Is it just a simple rotation until it seats?
Motorcycle engines typically fire the plugs many more times per mile than car engines, and I think the usually higher compression ratio increases electrode erosion. Those differences may not be linear - doubling the firing rate might cause more than double the wear.
You can probably squeeze more than 12K out of a plug, but unless you check them very frequently, you will probably be down on power and fuel mileage, and increase emissions. Running with worn plugs increases coil temperatures and can cause them to fail early.
Seems like a good spot to ask a question that's always bothered me.
Why do we need to change our spark plugs at 12K miles when cars, not even premium branded ones, have intervals of 30K, 60K, or even 100K?
Make sure to use a spark plug socket and not any deep socket. I misplaced my spark plug socket and tried using a general purpose deep socket. It got the old plugs out but when torquing the new ones it the socket froze itself to the plug. A quick trip to Oreilly's for a "spark plug socket" solved that. All that after completing the valve clearance and adjusting cam timing which all went smoothly.
Or get one of these
https://www.wunderlichamerica.com/Motorcycle_Magnetic_Sparck_Plug_Socket_14mm
Works great!
I have a coil removal tool for my 2007 R1200RT. Can this same tool be used for the 2020 R1250RT coil removal?
