Motor32
Motor32
It seems to me that if the fault as described on here is due to improper machine work on the calipers themselves only replacing the seals would not fix anything. The repair would need to include new calipers that do not have the machine work out of spec. I hope you get it fixed properly soon and that you get to ride again as well.
I've had the seals replaced first and they still leaked. Then the calipers were replaced from the recall and they still leaked. I think the problem is Hayes calipers are two pieces and bolt together (This is where they leak, I think), where the Brembo calipers are a one piece design, this is what I was told.
Steve
