brownie0486
Well-known member
If you set the correct cold pressure at 20C (68F) and none leaks out the pressure will remain correct as the tire heats up and cools down. If you set the adjusted pressure per the chart at ambient 100F if temps cool down to 68 by morning you will find the recommended pressure within 1 psi. And that goes for any increased or decreased temperature.
Just so I'm clear on this, as it's been discussed a few times in various threads.
If my garage temp is 100 degrees, I should be setting my tires pressures according to the chart instead of putting them at 36/42 as I've been doing? I should be setting them at 39/45? And conversely, if it's 40 in the garage, I'd be dialing in 33/39?
Thanks, I thought from other threads that I was supposed to ignore the chart and just set recommended cold temp pressure.
