Amsoil produces a couple of specific 20W-50 oils as well as oil for older engines requiring additional ZDDP. If you want to run a premium oil look no further!
OIL? I don't prefer Peanut Oil, but that's usually what I end up in.
Has anyone ever blown an engine due to a bad brand of oil? If not, they all must be fine.
So that's 1 maybe if you stretch it. Could it be that almost any oil is fine and these threads are a joke?
Just to simplify the posting process for others; feel free to use this template.
I've used (insert your brand of oil here) for over XX years and X00,000 miles, and I've never had a problem.
Don't know if it's considered "blown" but a friend continued to use an oil which had depleted amounts of ZDDP in the oil for his '65 R60/2. He was unaware that the manufacturer had done that. The result was flaking of the metal from the faces of the cam followers. Bits of metal were floating around in the oil, filling up his slinger. There's no proof that the oil caused the situation but there is a known relationship between missing ZDDP and health of tappets/lifters in those old engines.
Marty, I think most oil threads are to some extent a joke, and I appreciate your tongue-in-cheek humour.So that's 1 maybe if you stretch it. Could it be that almost any oil is fine and these threads are a joke?
...airheads should be using an SG rated oil which contains higher levels of ZDDP. Castrol 20-50 Motorcycle oil is still SG rated...
Yes, Spectro was the supplier of BMW oil until 2015. At the Salem OR. rally I spoke with the rep for Spectro , we had a very good talk. I do not know who makes it now.
I've used Mobil 1 15w-50 CAR OIL (OMG!) for over 8 years and 35000 miles in my 190HP ZX14 and I've never had a problem. Yes, a wet clutch.
I've used Mobil 1 15w-50 CAR OIL (OMG!) for over 6 years and ?? miles in my 160HP GSXR 750 race bike (usually at or near redline for 20 minutes each track session 6-7 sessions per day) and I've never had a problem. Yes, a wet clutch.
I've used Mobil 1 15w-50 CAR OIL (OMG!) for over 5 years and 5000 miles in my wife's EX500 (HP? not so much) and I've never had a problem. Yes, a wet clutch.
Using BMW oil for now in my GS just due to warranty paranoia.
Do these bikes have flat tappet cam followers or roller followers? Curious
