Thinking of installation of deceleration lights on my 2014 GSA.
Any recommendations for a guy who isn't too mechanicaly orientated ?
I tend to sorta agree with daboo. If the lights are sensitive enough to activate on a mild decel you will be constantly "crying wolf" to following traffic. What you really want IMHO is a really bright brake lite that when activated, flashes a few times to let traffic know "I am slowing/stopping NOW, FOR REAL. I personally like the programmable Skene lights as you can control the flash pattern and the LEDs are very bright. No vested interested, just a satisfied customer.
DG
Many of these decel type lights cat be set to different sensitivities to avoid that problem. It depends on how you ride your machine.
On the twisties I use decel and gearing more than brakes and when I hit the brakes , it's usually to warn H of something in the road or I did sometning goofy.
Skene design P3 lights are a better alternative In my opinion
I'll probably go with these. Not for deceleration but simply added blinking for braking only.
Here's another vote for the Vololight. I installed one on my RT about a year ago and have had drivers back off when the lights come on, after a downshift. There's some adjustment available and it just takes a moment with a magnet to move between settings. For moderate deceleration, the lights flash slowly. For heavy braking, they flash very quickly.
No worries with the CANBus because you don't go anywhere near it. Not sure what the case is with your bike, but you can tap into the license plate light on most bikes. On the RT the taillight is the same as the license plate light (one bulb – with a clear plastic lens on the bottom of the tail light lens). Instead I tapped into the passenger power plug line. It's on and off with the ignition, staying on for a few seconds after it's shut off. I did a write up on the install, complete with photos that you can see here. https://forums.bmwmoa.org/showthrea...ion-on-a-2011-BMW-R1200RT&highlight=vololight
