I've decided to have it changed at every 6000 mile interval service. It really does not add much relative to the total cost and it makes me feel a bit more confident.
I noticed that BMW now recommends a final drive fluid change every 12K miles as well as the 600 mile. At least for all the 2009 bikes.
US Lemon Law varies from state to state, but usually involve several attempts to fix a problem, and incarceration in a shop for at least a certain number of days within a given time period.
While this sucks, I don't think it fits any Lemon Law I've looked at.
Changing lube in FD and lubing splines [overlook by many..] is very simple to do...about 30 mins for me..most of that is slowly getting the FD refilled [220ml]..on my '07 you refill through the sensor hole and the process is very slow....
Paul, in post 1 here, it says "I dropped the bike off in late July and I'm still waiting to get it back." as of October. In AZ, the lemon law triggers at 30 days, and is automatic on day 31, besides 4 x repair of a driveability issue. I went through this with BMWNA with my F800S in October 2008.
Which is what I've recommended from day one. Be sure to use the proper 75w90 synthetic lube.
I guess their thinking is (as if anyone could know what their thinking is) was that the final drive is sealed from breathing air or water as opposed to earlier models. Once the drive is flushed (which was supposed to happen in manufacture before 2007), then the oil should last forever...heh.
Jack, Have you examined a pinion shaft seal or the axle shaft seal(s) in these units? I haven't, but am certainly curious as to how they imagine that a pressure vessel with rubber seals works as the FD heats up and cools down in normal use. And I also wonder if the ventless design is contributing to seals that puke oil all over, occasionally.
If Arizona law actually says that a single instance of a failure that takes BMW / the shop 31 days to fix is a "lemon" then there are lots of shops that need to speed up their repair processes substantially. Which would be a good thing.
New drive.
When the bulletin that came out recommending a fluid change at the 600 mile checkup, there was some reference to flushing the drive of manufacturing residue. I wondered if this was chemical or what. Having the crown and pinion toast is really odd. You mean the teeth mesh or is it the bearing surface on the pinion shaft...but not the bearing?
New drive.
