Who cares? Its maximum 20 bucks.But now that I think of it the final drive fluid needs to be removed to swing the drive down to remove the shaft. I wonder if they pay for the fluid, crush washer and o-ring
The SI bulletin covering driveshaft replacements does not include changing FD lube as it is not necessary to do so in order to change out the driveshaft. If you didn’t get charged for gear lube I’d not assume the change was performed.I didn't have to pay anything. I assume fluid change and all other required parts are part of the deal.
Are you saying, in the future BMW shops will do the driveshaft test every 12,000 miles and also remove the driveshaft so they can lube both ends?The maintenance schedule for all wethead R bikes (model year 2023 and older) was recently changed. At 12,000-mile intervals, the driveshaft is TESTED (it's not removed for a visual inspection). It's the same test that was performed on the wethead GS/GSA/RT-P in accordance with a still-ongoing service campaign (rear wheel removed, a special hub is attached and then spun with a cordless drill, while hooked up to BMW computer. It senses vibrations. If it fails the test, the driveshaft is replaced). That Service Information Bulletin overlaps with the more recent bulletin concerning changes to the maintenance schedules for ALL R-series wetheads. Test driveshaft at the 12K intervals, and regrease the splines. Automatically replace driveshaft at 60,000 miles of driveshaft use (which may not be the same as your odometer reading, if your driveshaft was previously replaced).
Items 8, 9, and 10.
I'm waiting for the equivalent policy for the chain drive models, free chain and sprocket replacements.Sometimes I really like my chain drive.
If the dealership in question has actually read the applicable Service Information Bulletin (33 04 23, dated December 12, 2023, and Entitled "Info: K5X Driveshaft Maintenance Schedule Change"), it tells dealers that the maintenance schedules for ALL R-series wethead bikes (K5x models from model year 2023 and older) have been changed. The updated schedules for those bikes now call for the driveshaft to be tested ("ISTA-led test method") every 12,000 miles, and the splines greased (the Bulletin does not say if it's both ends, or just the rear end). At 36,000 miles (of driveshaft use), the driveshaft is to be replaced. These new maintenance requirements are all covered by warranty. if the driveshaft fails the test at one of the 12,000-mile intervals, it is to be replaced then. Here is a direct quote from the Bulletin: "The replacement check and regrease of the cardan shaft (driveshaft) is covered by warranty and is offered to all customers that own a K5x motorcycle model year 2023 and older and unlimited miles or general service behavior of the customer."Are you saying, in the future BMW shops will do the driveshaft test every 12,000 miles and also remove the driveshaft so they can lube both ends?
In another post it was said the R1300GS owner would have to pay for the driveshaft replacement at 48,000 miles.By the way, the replacement interval for the driveshaft on a 1300GS is 48,000 miles, and not the 36,000 miles for K5X models.
Correct, as it’s now listed as a maintenance item in the rider’s handbook and the service schedule.In another post it was said the R1300GS owner would have to pay for the driveshaft replacement at 48,000 miles.
2024 is still the 1250 motor. They will test every 12k miles, replace if warranted at that service, and replace every 36k miles of use. I.e. - if it fails a previous test, it will get replaced, which then starts the 36k mile clock over. The "new" shaft may be slightly different, but they are still replacing it every 36 (and the price of the shaft is considerably less than before, so it may be the same shaft with a lowered price and new part number.) From what I've heard, lubricating the ends is an optional service that is not paid for, but test and/or replace is FOC.Can I ask if the new driveshaft is a better design? Do the new bikes have this improved design?
IOW, I am thinking of buying a new 2024 RT. Is BMW going to just replace the driveshaft with the same at a pre-determined mileage? This seems crazy to me.
