I'm trying to debug a Wonder Wheel issue on 2011 R1200RT with Audio and NavVI. The Audio computer is unresponsive to the right click and the NavVI doesn't respond to the wheel.
More specifically, the computer does not respond to pushing the Wonder wheel laterally towards the center of the bike. This is the "b" position referenced in the manuals. All else works fine and I can get everything working except the right click and NavVI doesn't respond to wheel for zooming in and out. I can't reset Bluetooth pairing and is a bit of a pain to only be able to click back through play lists and radio stations.
I bought this bike used and as-is knowing there were issues here. Otherwise it is a great bike. And, I don't really need it. Siri and my helmet audio takes care of music, coms, & Nav. But, I get two satisfactions out of bikes one is riding and the other is debugging, repairing, improving, etc.
So, here is what I have done so far.
Removed and examined wiring from wheel to plug at audio controller. No issues
Validated all harness connections with shop manual specs. No issues.
Unseated and reseated wiring harness connections for audio and nav. No Change
Tested with a new wheel. No Change.
Unwrapped wiring harness tape from Audio controller to main stem to look for issues. A couple of kinks that were suspicious.
Tested with a used but equivalent Audio/Nav Wiring Harness wiring harness. No change.
Any experience or ideas a next step are appreciated? All I can think of is that somehow it does not have the correct software configuration. So, I'm thinking a dealer software eval is next step. Audio system data are not supported by my GS-911 for this model year.
Thanks in advance for your help.
