Welcome, Guest! We hope you enjoy the excellent technical knowledge, event information and discussions that the BMW MOA forum provides. Some forum content will be hidden from you if you remain logged out. If you want to view all content, please click the 'Log in' button above and enter your BMW MOA username and password.
Over the weekend, I got the tank back from the pin stripe artist. I have installed it, with the original English type, brass slide blade petcock (which I had to hand make the internal cork sealing disks for) on the tank. After installing the tank, I sat down on this machine for the first time. I discovered that the curved mounting plate that the nose of the seat mounts on, was badly worn out, the bolt hole was a very sloppy fit of the bracket to the 8 mm bolt. I removed the bracket, and drilled the hole out to 9 mm and made a VERY thin walled tube, out of of nylon round stock, on the lathe. I fitted it to the bracket, shoved the nose bolt through, and eliminated the horrible side to side wiggle the seat had. One one problem solved. The top of the tank, as you can see, is BMW emblem blue. Yes, it is supposed to be. The R2 and R4, on the introduction year, had those distinctive blue tops to the tank..
If you look close, you can see the gas cap in the right, and the speedometer on the left, of the top of the tank. Word out of Europe is that my hand made rear fender will be shipped to me in Oct. Cross you fingers!
Just started coming over here more often...fantastic resto...Have to go see it close up when I drop off a engine soon. And the other beauties there as well.
