vivapuccini
Just got the bike. It's been sitting for a while. Oil filter is stuck. Won't budge.
Any trick to make it easy?
Yes, but put a drain pan under the filter and punch one hole first, so the oil in the filter drains out before you insert the first screw into the filter. DAHIKA good fitting filter wrench/cup is important. Did you warm up the bike? If all else fails, drill 3 holes in the bottom of the filter wrench, then drive 3 screws through the wrench into the filter. That will hold the filter to the wrench.
Any update on your oil filter dilemma? Lots of great advice here on this forum. Did you have any luck removing the filter?Just got the bike. It's been sitting for a while. Oil filter is stuck. Won't budge.
