Needed to change my oil(s). When It was time to drain oil from final oil, I discovered the drain plug was rather tight. I backed it off and after the oil had drained out, I gingerly screw drain plug back in but found it could not be tighten?? Further investigation, the drain plug had been striped and evidence of metal (aluminum) shavings were found in the threads??. Hmm, Ok, I have several options. What would you do? Would you get it re-treaded...gasket tape around treads and screw back in....?
Thank You
Thank You
