92 R100GS. Dual plugs. 9.5 pistons. Wedgetail ignition, timed correctly (confirmed with Mark in Australia). Valves set properly. Carbs cleaned with all new o rings. Butterflies installed and working correctly.
Needle jet 2.68. New needles on third notch down.
Only remaining issue...lots of popping closing throttle at and under about 3000rpm. True with both 145 and 150 mains.
As an experiment I set idle high...2000 rpm. No popping. Comes back at normal idle setting.
Thoughts on what to do next?
