typ181r90
Superkraut
I don't know if anyone cares about this but I haven't heard of anyone actually doing it so I figured I'd post my plans and results. Maybe another round slide alternative to Mikunis.
Here's the scoop
Currently my R90/6 has the Bing type 64 CV carburetors in their stock configuration with the exception of drilled holes into the airbox to allow for COOLER air to reach the carbs (not more air as it seems like people confuse it for). It's actually running perfectly, but it seems like once I get everything perfect I have to start messing with things. Engine is stock with the exception of SJ light aluminum pushrods and this February I'll be putting in 9.5:1 pistons with freshly bored/honed cylinders, lightening the flywheel, and getting the heads tapped for dual plugging - want to have that option but I'll leave them plugged until I save up for the the rest of the equipment. I got a fresh valve job last winter and wish I had that done at the time but no biggie.
With this work being done I thought of switching my Bings for Mikuni round slide carburetors or Dell'Ortos (if I could find them for the right price) running velocity stacks. I don't personally know anyone in my area who did the conversion so I've only heard of the benefits (easier starting, snappier response) but as I don't have personal experience I don't know how dramatic the difference would be. Not wanting to invest a lot of money I found instead two Bing type 84 carburetors in 32mm bore (like the type 64) for $38 and $56, I wound up buying a 3rd, never type just for extra parts. I ideally wanted a Bing type 54 in 34mm bore, but couldn't come across a pair in that size.
With the Bing 84 you're essentially getting a Mikuni VM32, which rocky point sells for around $460 for the kit. I own the Bing carburetor manual for BMWs which I haven't had much use for until this point. As the type 84 in addition to the 64/53/54/55 are all included in it it gave me a lot of information on parts numbers and jetting from which I was able to determine:
- it uses the same float bowl as the early type 53 carburetors and gaskets
- the float bowl depth is the same as the type 64, except for the ones which I'll be using that have a main jet reservoir
- it shares the same choke piston as the type 53
- the type 53 throttle cables work with it (got them on sale from eurotech, $28)
- Main jets and needle jets are the same as the ones in the type 64, the jet stock diameter/thread/and length are the same as the type 64 but I don't know if the mechanical pump in the type 53 will work, but I doubt it
- pilot jets are the same
- the floats match the ones in the type 64, I'll actually be using my ethanol resistant ones that I'm currently using for this experiment
- the atomizer is pressed in on the type 84 and this is part of the equation I can't really account for
The beauty of all of this is that all the parts can be bought from BMW and in my case a dealer is only 5 miles away. Additionally, the manuals for the carb can all be found on Bing's German website www.bingpower.de
the carb broken down, sorry for the crap cell phone pics
the new type (tabbed choke adjuster and metal clamp style) in comparison with the older type (a simple pull and lock choke and additional float tickler) intended to use with a rubber hose mount like the stock ones. I'll be using 2 of the older type and keep the newer one for parts.
Note the old one without the main jet reservoir in the float bowl, I'll be using the reservoir type on both my carbs
Finally here's a pic of the velocity stacks I ordered. I couldn't find a whole lot for the OD I needed and the ones I could find were threaded. These popped up on ebay which were designed apparently for the Type 84/54 carbs and are coming from Argentina. I like that they have a foam filter element on top of the screen, but I'm dubious as to how they'll function, may just continue to go with the stock airbox set-up. The dimensions of the stacks are quite large and should work fairly well, 108mm length x 94mm diameter
I know I'm going to have to experiment with jetting and currently have 145, 150, 160, and 170 main jets, 2.68, 2.7, 2.72, and 2.73 needle jets, and 240 old style needles (may need to get some different ones if I can't adjust the mix enough with using the notches)
Here's a breakdown of the cost:
Carbs - $94
Cables - $28
Rebuild kit - $25 (only needed one)
Misc. jets - apx. $40
New choke pistons - $10
$197
The velocity stacks were $109 with shipping but I'm not going to include those with the carbs because I'd be buying them anyway with Mikunis.
If I can get these carbs working pretty well, that's a significant price difference to the Mikuni kits and Dell'ortos (which I can't find cheap anywhere) and you'll have period correct, German built carbs. Furthermore if they don't work I can always reattach my perfectly working CV carbs and I should be able to make back most of the carb money by selling them, now fully rebuilt.
Still waiting for the velocity stacks to arrive, maybe by the end of the month, and will update with my progress.
Here's the scoop
Carbs - $94
Cables - $28
$197
