95 R80
Its fixed, but I still cannot really explain why this occured.
Had the carbs vapour blasted and I reassembled them. Tweeked the fuel levels by gently bending tab on the floats with carbs inverted.No Problem.
Refitted carbs and RHS carb's fuel bowl will not fill with fuel.....
Took the bowl off...floats hanging down. Still no fuel. Removed fuel line from carb and fuel pisses out. Refit fuel line to carb, still not fuel.
Remove float...needle still attached to float with wire clip....needle not jammed up against seat.( could see if moving with the float. )
Blow through fuel port on carb with compressed air. Clear. Refit fuel line ( still with bowl off ) still no flow....
Had bowl on and off a few times ( though it was hanging the floats up....not different. Tried to swap bowls...no dice, they are 'sided'.
Started to swear profusely....
Removed float ( again! ) inspected. Could not see any reason for problem, except floats were 'slightly' misaligned.....replace. no flow....
I found a NEW set of floats in my spares....compared them side by side. Could not see any marked difference, except fuel level tang was not set yet.( as expected )
Fitted NEW floats anyway!, set the float heigh as before, refited Carb to the bike with fuel bowl off and connected fuel line. I have fuel flow!
Replaced bowl...Still have fuel flow. Bike starts normally.....
It must have been something to do with the original float but buggered if I know why or how......very annoying!!!!
Never had such a problem before. I had leaking carbs,butterfly refitted wrong, idle jets blocked, fuel bowl jets blocked,fuel level too low or too high, but not this.....grrrrr
I am better now.....
