tmwilmotte
Member
I just recently bought a used 2009 RT and I think the ESA may be malfunctioning. Is the motor supposed to change the position (lower/higher) of the rear shock? With the ignition on, when I cycle thru the damping settings (Normal, Sport, Comfort), I don't see or hear any changing taking place. Also, with the engine running, it doesn't seem to adjust the spring preload settings (no visual change in shock or noise from the ESA shock motor). The reason I am concerned about this is the seat height is currently about 34" from ground level versus the 32.28'' that it's supposed to be. I had a 2004 RT and had no problem flat-footing it and walking it around (straddling the saddle) in the garage. I can barely do this now because the seat is too high. I'm 6 feet tall with a 32" inseam -- I didn't think I would need a low seat. Am I supposed to be able to hear the ESA motor adjusting the rear shock? If it's broken, could it break in the "high" position making the seat height about 2 inches higher? This is very puzzling to me.
