aftermarket starter relay
thanks all
Thanks all, for your replies, I have also dealt with EME moto electrics, including a gear reduction starter (made in china) and is doing a good job this last few years, I was told I should have installed a higher grade starter relay, due to higher draw, and they all seemed to be 30 amp, that what is installed, so I removed the cover and could see no signs of overheating, so cleaned it up inc contact tips, and reinstalled.with heat sink grease,so all should be well for the riding season, thank you all once again, Jimmy:thumb
Glad you are up and running. One question though... Where and why would you use heat sink grease (paste?) on a starter relay? Are you confusing it with the ignition module mounted nearby?
A word of caution; I've had limited success with cleaning up (sanding or filing) point contacts or relay contacts and having them last any length of time. Usually when they get worn enough to arc etc. it's advisable to replace it or at least make sure you carry one as a spare. :thumb
thanks for the concern
Hello, I used the paste on the connections spade terminals, and your right not to emery the contact tips , I just cleaned it all up as there was no sign of overheating,I also have a spare under the seat, so all seems well ,except the snow has returned to south west Ontario, oh well! thanks again Jimmy
