larscwaldner
Just got the bike back together after being flooded and varmitized. Ready to start. Hear a click in the starter relay and thats it. Checked...
battery for voltage
checked starter and solenoid
neutral switch is shorted
clutch lever is pulled in and switch checked
ground is tight
Bad starter relay? Is there a way to check? Looks like it is wired correctly although couldn't find a diagram and the bottom of the relay has no coresponding numbers.
battery for voltage
ground is tight
