kjschilling
1974 R90/6 charging issue/questions, (non-stock charging components)
Recently installed:
• EME Enduralast III alternator kit (rotor, stator, diode board, adjustable voltage regulator, wiring and connectors)
• Westco 12v/30ah AGM battery
• Enduralast starter “cricket” relay
• Enduralast engine wiring harness
• Enduralast battery cable kit (4 gauge)
• Katdash dashboard light upgrade
• 3 ohm dual post coil
All contacts between components and ground points and connections between wiring and posts were cleaned and had a thin layer of NO-OX-ID applied
Issue is charging light remains on (or at least flickering with reduced intensity) even as I increase RPM’s.
As part of my troubleshooting efforts I purchased the CHITECH BMW Electric School Manual from the Chicago Region BMWOA.
In appendix C there is troubleshooting process for testing of the alternator charging circuit;
test 1 (static test w/ignition off); checking for the charge light to be off when ignition is off; my bike passed this test
test 2 (static test w/ignition on, engine not running); checking for charge light to be on when ignition is on; my bike passed this test
test 3 (dynamic test w/system running); part of that test is to check VDC across battery with engine running at 4,000 RPM. Since my bike runs with lights on all the time, voltage should be 13.8 to 14.4,,,,my bike shows 14.4 yet the charging light remains on (flickering with reduced intensity (and occasionally completely out) as compared to when at 1,000-1500 RPM idle the light is on solid and bright).
The fault table C-2 describes the possible cause as “poor connection between the battery and the charge light (most common cause is connector on starter relay)”.
The “how to check” for this condition calls for a cleaning of the starter relay connections and if condition persists to do the following: with ignition on place positive test lead on the “point to be checked” and the negative test lead on the chassis ground. The various “points to be checked” are listed as: positive battery post; positive side of charge light; ignition switch; starter relay and fuse.
I did check and clean the starter relay wiring connectors and applied a light coating of NO-OX-ID to the starter relay posts when first installing the new starter relay
The following is some data I collected while awaiting the above mentioned electrical manual;
12.4 VDC between batt positive and frame ground with ignition on, lights on and engine not running (fully charged battery at 13.5 VDC across terminals, everything off)
run test results
13.7 VDC @ 1500 RPM
14.35 VDC @ 2000 RPM, 2500 RPM, 3000 RPM, 3500 RPM, 4000 RPM and 4500 RPM
13.45 VDC across batt 3 min after run test, everything off
Batt back on charger for 1 hour resulted in 13.5 VDC across batt
At 2500 RPM and above during dynamic run test charge light would flicker and @ 4000 RPM would occasionally (most of the time) go out completely but at 1000 -1500 RPM light would be fully and brightly on
My (neophyte) questions are: is there/are there any specific posts on the ignition switch and the starter relay that I should be testing with the positive lead (as recommended by the CHITECH manual)? And since I have a KATDASH dashboard light upgrade is there a way to test the charge light (as recommended by the CHITECH manual)? Is there any other advice, guidance, insight anyone has to offer as to next steps?
Recently installed:
run test results
13.7 VDC @ 1500 RPM
