2wheeljunkie
My 1972 R75/5 is having issues with electrical and/or starter. For the past few days the battery hasn't been charging properly, or I don't think it was. At first I thought it was the battery, or the connection to the battery, as the first time this happened I found the wires t to the positive post loose and believed that was the problem, as the battery tender is connected there as well. I got bike started with the kicker and thought a good run would charge the battery, at least enough to start it. But, I had to keep using the kicker every time I shut it off.
I left the battery tender on all night and most of today, but when I checked the bike, the charger was still on solid red, indicating no charge, or that it was still charging. I tried the bike and no response at all, not even a click, click, click like before. I tried the kick starter and it almost started, but it died, and I couldn't get it to offer again. So, I thought I may as well take the battery out and go get another one. When I started to remove the leads to the battery, the starter engaged, even though the key was not on. I should add that every time before, when I pushed the key down to start the bike, all 3 indicator lights (green, red, and yellow) would show, and the headlight would beam if I turned it on, so I am quite certain the battery had some power. The bike was still turning over, although quite slowly, and I had to totally remove the battery lead from the post to get the starter to stop. There must be a short somewhere, but electrical is a weak spot for me so not sure where to begin. I am thinking that maybe the wire to the starter may be loose, but that is just a guess. And I am not sure why the starter was trying to start when I wasn't pushing the button and the key wasn't on. I am also guessing that there must be some kind of drain on the battery to, either keep the battery tender trying to bring it to full charge, or the drain is taking most of the battery's power, and maybe it's because I had the charger still connected and charging that kept the 3 lights on.
Any suggestions or advice greatly appreciated.
