musclehealchance
Oilhead Owners; I recently removed the front wheel of my R1100 in order to replace the rotors, thus everything was removed involving sensors, speedo/tech fitting, etc. including the rotors and sensor rings of course. Purchased replacement rotors/bobbins, etc. Now after reassembling the front brakes duo not engage on the first draw of the lever but will engage on the second pull. On the first pull there is nothing, very soft then on the second ull it pressures up and functions normally. Recently bled all 3 bleeder valves and replaced with DOT 4 Fluid and there had been no issues until the front wheel was refitted. Fluid levels up to par, no visable air in lines. No flashing ABS system failure lights. Why no action on the first pull but on the second. a very dangerous circumstance and will not ride till resolved, thx. Bill Ed.
