Grover
ShinySideUp
Recently I added a Garmin 2820 to the bike using the GARMIN StreetPilot 2820 GPS DATA BMW Amplifier Harness Kit Cable. This attaches just below the handlebars to a white pin connector. The GPS powered up and I was ecstatic. The GPS then powered off after about three minutes, stayed off for a few minutes, and then came back on. Never really long enough to get a fix. I restored the GPS to defaults while it was on quickly and it stayed on. Turned the bike off and the same thing started all over again. The Garmin is fully updated. I did not have this problem when it was directly connected to the battery on my RT, but I no longer have that wiring harness. This is a BMW part I am using to connect the GPS to the amplifier cable. Does anyone have an idea what might be causing this issue?
Thank you!
Thank you!
