I have the rebuilt transmission in my possession, and decided to mount it back to rear of engine tonight. It has been a few weeks since I removed it, and my notes are less than copious, so that now I am unsure as to how these tiny bits are to be aligned, and furthermore, what are they for?
First bit:
The bottom sets of bolts that hold the transmission to the engine block, had this black-strap thing mounted with these two bolts. Did I orient it correctly? And two, what does it do? What does the flange do, which is shown on the left, bent forward, from the lower left screw?
Second bit:
On the left side of the engine, when facing forward, the middle bolt had this little curl-thing on it, shown at the tip of the screwdriver. Is it oriented correctly, and what did it hold?
Third bit:
On the right side of the engine, when facing towards the front, the middle bolt again had a small pointed strap. I oriented it in a way that seemed to fit, so again, is it oriented correctly, and what does it do?
Thanks for taking the time with my puzzle, but I am striking out on the micro-fiche, manual, and service CD.
John(I used to know what they were for)
First bit:
Second bit:
Third bit:
