I have a 1971 R/75. It has good compression. strong spark and fuel in both float bowls. However, it won't start. I tried starter fluid but got no combustion.
I thought the problem might be timing so, following the manual, I attached a contimuity tester to the condensor and a ground. Based on the manual the tester should buzz when the points are closed but it buzzes constantly. Why would it do this? Additionally, if there is something wrong why am I getting spark?
Any advice would be appreciated.
