Unfortunately, the same pricey results for me.
Wow. Thanks for those posts. Saved me a lot of money.
I've had 3 or 4 custom plugs made. Two of them were done at M/C shows, each by different company, but both using the foam in the ear injection molded stuff. Both of these styles were quite large, and fit flush with the outside of the ear canal. Both pair were easily dislodged, and both transmitted noise from the helmet into the ear. Absolutely worthless. I also had 2 pair made by an Audiologist's office. These fit deep inside the ear canal, much like ear buds and worked quite well. I could wear them all day long without discomfort, and when you put them in, you got "the world disappears" sound. Could still hear the stuff you needed to hear, but made wind noise vanish. Still like the S Plugs for an off the shelf solution.
Disposal, foam earplugs, Howard Leight, Laser Lite, bought by the 200 pair box work best for my ears. I use a touch of mineral oil in my ear canals, to assist in sliding them in place. They do an effective job of blocking wind noise and yet allow me to hear the GPS and music (if so desired) through the helmet speakers.
I have three small cases that each hold two sets of earplugs. When stopped, I rotate through the six pairs of earplugs, allowing each set to recover their former size, and allowing a slightly longer use with each pair.
Having said that, I plan on buying and trying a set of No Noise earplugs this spring. Hoping they work as advertised, allowing me to turn the Sena to a lower volume when listening to the GPS and streamed music, as well as being able to carry on conversations at gas stops. I am somewhat skeptical, but I won't know just how well they work until I give them a try.
Does anyone have any advice on a set of ear plugs that I will still be able to communicate to my wife through my com system in our helmets but cut out wind noise and etc??? I have been on the internet and there are so many. I do not know which ones really work and which ones are hype. If you have any information or experience with ear plugs the information would be greatly appreciated!
Dennis
