Windscreen problem
ndrhsr
My '14 RTW windscreen going down at turnoff or returning to up position upon start off has stopped working. It still functions manually with the switch. Has anyone else experienced this problem?
This may sound dumb but you do realize it does not go back up until you have ridden about 100 feet.
I have experienced this maybe a half dozen times in 84,000 miles on my 14RT . I just adjust it as I'm moving and it's ok again for many miles , don't know why it happens but don't consider it a problem .
Found out that as I turned off the key if I applied some pressure on the windscreen it would retract . So lubed up the pivot points & all has returned to normal.
