vwsandman
Active member
So you may have seen my No Spark Thread. When I picked the bike up and rode it home all was well for the most part. A few niggles and parts not put back on right from the dealer. No biggie. I noticed the left front turn signal was acting up. After I got home I started to address the niggles and finish up some farkles. All went well until the Wunderlich bar conversion. After getting it all back together I noticed the turn signal switch felt "Off" to me. I noticed that the turn signals and the horn did not work. After taking the left multifunction switch back off and peering around inside and much head scratching, I got the GS 911 out and went to the real time input for the Kombi (instrument cluster) which takes these inputs in from the left Multifunction control (and the right) over LIN bus I believe. There you can push each button and see if the Kombi recognizes the input. Lo and behold, the turn signal buttons for left and right and cancel as well as the horn were not recognized! All of the other switches from the same LIN module were working! Dang it! What to do now? It is a CPU and Ribbon cables and little switch buttons! I'm not going to ride to Arizona with no turn signals and no Horn! It's Sunday too and the dealer is closed on Monday! ARGGHHHH??
But wait, don't I have a 2022 BMW S1000RR sitting right over there? Hmm, how much you want to bet BMW makes a single left multifunction switch and changes the buttons for what bike they go on? I bet the internals are all the same and that the Kombi takes whatever switch input is on and then performs the function based on it's bike specific coding? Yep!
After a quick switch a roo this morning I am pleased to say it all works again! Now to either fix or source a new Left multifunction switch for my beloved cursed R1200RS!
You can't make this stuff up!
I guess I must have messed something up during the handlebar installation?
