I'm replacing my push rod seals and some gaskets. Want to see if I'm creating any issues. Here's what I've done.
I got the left side back together torquing in the recommended cross pattern, at 15, 25, 35, then 39 Newton meters. And then I found the rocker arm assemblies were very tight. So tight they didn't move at all.
I had set it at OT for that side but thought maybe it moved while I was working on the bike.
So I did the whole procedure to get to (OT) top dead center for the side i was working on again (valve was coming out).
After that, when I loosened the nuts the assemblies moved OK and I was able to go through the procedure of adjusting them.
First question. See any issues so far?
They were still tight but moving a little, which is, according to my research, where they should be. I then adjusted valve clearance, put the cover back on and moved to work on the right side.
I started by taking the intake rocker arm assembly off and started to loosen one nut on the exhaust rocker assembly when I remembered, I had NOT put the bike OT for the right side. Quickly put the intake rocker assembly back on but I forgot to tighten the exhaust nut. Then I moved the wheel so the crank went through one 360 degree cycle to OT,
Now I didn't look to see if the exhaust valve was coming out. I just assumed if I started at OT on the left side, and went one revolution to OT again that would put the bike at OT for the right side.
Second question, is that correct? My understanding of it is if you're at OT on one side, then go through one revolution to OT you're good for the other side. Then, if you go ANOTHER 360 your back at OT on the initial side you started at. But am I right?
Third question. Did I mess something up by taking off the rocker assembly when the right side wasn't at OT?
