dodge1chevy2
I noticed a couple of days ago that the left turn signal indicator bulb on the dash of my '82 R65LS was dead. The turn signals (both left and right) worked fine. So, thinking that the indicator bulb was toast, I pulled off the faring and instrument cover today in order to diagnose the problem. This is probably where my lack of electrical "expertise" failed me. I left the connectors for the turn signal bulbs disconnected, turned on the ignition, and watched the turn signal indicator lamps. Well, it turns out that both connectors for the right turn signal were touching and the indicator bulb was blinking rapidly! I turned off the ignition and connected both the right and left bulbs to the connectors. Now, neither turn signal bulg nor indicator bulb worked. The bike started fine and headlight and tail light work fine.
So, did I toast the turn signal relay or destroy some other electrical component? My Clymer manual does not even indicate where the relay is located?
A search of real.com did not give a part number for the turn signal indicator bulb. Any suggestions where I can find this?
Any help will be greatly appreciated.
rickt
rickt
