Tire changes. Not sure what the fuss was about.
c10950
Member
I've come across complaints of BMW wheels being difficult.
I can say zero issues with the 2023 RS of mine .
Have a 2023 GS of a friend that I'll be doing tires on is a few weeks and will report here if any difference.
Adapter for wheel balancing was great .
FYI I didn't even need a tire spoon today 🙃
No exhaust removal needed either. Close but cleared
The bead on GS tires is a complete pain in the butt. The drop center in GS wheels isn't all that deep, so they can be a bit recalcitrant.
View attachment 93354View attachment 93355View attachment 93356View attachment 93357
Nice setup. Congrats on a job well done, and I have to say that's quite possibly the cleanest wheel I've ever seen. Was the tire worn out, or did you upgrade to a better set?
GO ASTROS!!!
E.
I have a 2018 R1200RT. IMO, it is fairly difficult to swap tires.
I rode Harleys for a few years, I thought tire changes on them were tough, but after doing a few changed on my RT the HD rims are easy! I have learned a few tricks that have made it easier.
Worst one was a buddy's wife ride a Can-Am Spyder. They just plain suck! I changed out one set for him and told him the next time take it to a dealer! I won't do them again. It was over three hours just to swap the tires. He brought just the rims and tires to my shop.
I don't know what you guys are doing but so far, I have no problems changing tires on Harleys, GS's and CamAm's I must be missing something.
Tire changing can be far less challenging when the right tools for the job are available.
Tire heaters.
Pneumatic/Electric tire changer.
I’ve changed 97 tires using this style machine in the past three years. It makes working with difficult wheels and stiff walled tires a much easier task.
Tire heaters.
WoW, that’s some nice equipment. I need a new front tire on my tube-type F800GS. I’m not looking forward to doing it myself on my hands and knees. I may try the local Honda shop figuring with all the dirt bikes, the tube shouldn’t be as much as a problem as it seems to be with shops doing a lot of tubeless tires.
akbeemer my brother has the same machine , and its nice . I just do not have the room for one in a small 2 car garage.
Can am wheels are easy and I have done them on this manual machine for a friend . They are a Car wheel and the tire only comes off on one side .
I do about 4 sets of tires a year for my bike , and another 5 or 6 for friends . Wifes bike gets a set about every two years .
It's not so much the wheel, or drop depth, or width even. It's the stiffness of the tire or the temperature of the tire that affects manually changing the most. Right behind that, for me, is my change in age, from 40's to mid-seventies. YMMV.
I have a Nomar with all the rim gizmos and have used it on tube and tubeless tires, Harleys, Suzukis, BMWs (K, S, R), and Hondas. The "GT" version of tires for my RT are by far the worst I've encountered. On a couple of brands, I even had to resort to Goldwing-style measures like adding small wooden blocks in the drop zone to keep the bead down enough.
I've even laced my own wheels in the past.
Do I wish I had a commercial grade tire changer? Sure do, but I'll keep trying until I can't anymore.
kbasa
Wow, I had to look that one up. Good one. :thumb "Having an obstinately uncooperative attitude toward authority or discipline."
I use a cycle hill tire changer on my 2010 R1200RT. Also don't see why "it's sooo hard". Once the wheel is secured to the changer, it's 5 minutes or less to slide the tire off and on.
I have watched various YouTube videos and see why some struggle: no lubricant used, not properly getting the tire into the drop center. The rear wheel on the R1200RT does not have a drop center to speak of. But with appropriate technique and lubricant it just slides on.
I have been using this changer since 2012 and at first I also struggled. But it's all technique.
Reminds me of one of my favorite scenes from the old sitcom Wings:
LOWELL: ...I'm seeing a beautiful friendship torn asunder, rent in twain, bifurcated.
HELEN: Lowell, have you been listening to those stupid vocabulary tapes again?
LOWELL: Indubitably!
That is a thing of beauty!
"Recalcitrant" - politically correct for a PITA.
And I thought "indubitably" was a Spock-ism...
I had to look twice at the city... there's actually a brothel in Washington? Yeah, my mind is in the gutter.
Ya, nice wheel!
Ya, nice wheel!
Thanks.
In some signature lines on other forums I sometime type it as "Bot-hell". There's not much difference. :groovy
No fuss at all if you have a tire changing machine....which I now have. An OLMAXMOTORS tire changer.
Try doing it with two 10" long spoons while the Michelin Anakee III tire is on a couple of 2x4 pieces of lumber to protect the rim. And try getting the tire into the drop center without using any tools.
My friends 2023 GS he bought new this summer . Millage 7,3xx and the front had a very slow leak since new . Unable to locate issue with tire or bead. I discovered the leak at the stem . After removal with no spare stem or seal a little gentle work I was able to clean up this seal , and get the leak resolved vs warranty , and sitting at dealer for a month . Going to order a new unit for his next set of tires .
The GS wheels were no issue to mount or balance.
