With this big storm moving across the country, I decided to get out ahead of it for a quick ride. So, I took an overnite trip this weekend from Colorado to southwestern Kansas. Great weather on Saturday on the ride out, but really lousy on the trip back on Sunday. I left Meade, KS Sunday morning at 8:30 am and the temp was 21!! It didn't get above freezing for the next 250 miles!!
On the trip I noticed a couple of problems with my '95 R1100RS, and seek some advice.
1. Trouble up-shifting. Mostly from 2nd to 3rd. I'd pull in the clutch lever and pull the shift lever up, but it didn't shift. This happened several times. I'd just keep trying until it moved up to the next gear. I also noticed this happening when going from 4th to 5th. Does this sound like the clutch cable needs adjusting?
2. Heated grips: The right grip did not work at all, and the left grip worked, but sure not enough!! I suppose at 21 degrees, it would be hard pressed to produce sufficient heat?? I'm guessing that this must be a broken wire somewhere in the circuit to the right grip. Any suggestions on where to look for an easy fix?
3. Kick-stand kill switch. This hasn't worked for the last few months, ever since the local shop performed a spline lube on the bike. I'm guessing they boogered it up while disassembling the bike. I'm guessing this is likely to be a broken wire and will start looking around the kickstand itself. Also, is it likely that some road grime has messed up the switch?
With this storm coming in, looks like I'll have a couple of days of down time!!
Thanks,
piperjim
Thanks,
piperjim
