brittrunyon
'92 R100GS
I just finished cleaning & greasing the steering head bearing for the first time (50k miles) & after reading Snobums & others articles, I'm still a bit confused on the adjusting procedure.
The image shows the adjustment nut marked prior to removal.
<a href="http://s1089.photobucket.com/albums/i358/brittrunyon/?action=view¤t=PB133751.jpg" target="_blank"><img src="http://i1089.photobucket.com/albums/i358/brittrunyon/PB133751.jpg" border="0" alt="Photobucket"></a>
1. Do I tighten the allen bolts on the top brace to secure the fork tubes & loosen (as I have read) the lower brace bolts to allow the forks to move up or will having the top bolts loose allow the bearing to seat?
2. Is the first adjustment done with the adjustment cap? Seems I have to use channel locks on the adjustment cap and snug it up "really" tight (going past the original mark) to get the bars not to fall to one side or the other.
3. Then it's the cap nut to 47 ft lbs.
4. Then it the lock nut to 47 ft lbs.
Is this right?
There is no "notching" noted
Is this right?
