rwadamsidaho
Member
Concerting your F850GS's front end with a high-performance, closed cartridge fork kit from Touratech Suspension will wake up the front of your BMW and make a huge change in handling, stability, and performance in any of the on and off road conditions you find yourself riding.
Not just a change in spring rate, or a simple re-valve, this cartridge conversion completely transforms the front-end of your F850GS with all new damping characteristics that can't be achieved with the stock F850GS or GSA forks.
The F850GS and GSA use a single fork leg to control both the compression and rebound damping, this reduces the weight of the forks to improve steering responsiveness both on and off pavement. The Touratech single sided cartridge kit replaces the stock internals with much more capable components to drastically improve the wheel control without adding unnecessary weight to the fork. Additional benefits of this design are a significant reduction in installation time and complexity as only a single fork leg needs to be removed from the motorcycle.
Gone are the days of non-adjustable stock front suspension. The Touratech kit is completely tunable with rebound, compression, and preload adjustments made from the top of the fork caps. No matter where your adventure takes you, you can be assured that our cartridge system is designed to go the distance and tackle any terrain you throw at it.
BMW F850GS & ADV Touratech Cartridge Conversion Features:
•Easy Installation with simple "drop in" set-up. No irreversible machining or rework required. This kit includes everything you need to install the cartridge in the right side fork leg, and a decal to put on your left fork cap so they match. The cartridge comes pre-sprung, filled with oil and charged with nitrogen. Simply install and ride.
•Closed Cartridge separates the air and the oil to prevent oil foaming. This direct damping technology ensures that your fork will have smooth and consistent performance even in punishing environments.
•Separation Bladder delivers lightning fast responsiveness due to minimal friction and eliminates foaming by pressurizing the oil.
•Adjustable compression damping allows absolute control of fork tuning to give you the precise handling characteristics you want in any conditions. With 20 clicks of adjustment you can control how fast the fork compresses. If it feels too firm, you can reduce the compression damping. If the bike is going through the travel too quickly, feels too soft, or is bottoming out, you can increase compression damping.
•Adjustable rebound damping allows you to fine-tune the ride characteristics to meet your preferences. With 20 clicks of adjustment you can control how fast the fork moves back out. If it feels bouncy you can increase compression damping. If the fork is progressively using up travel (packing) you can reduce rebound damping.
• Preload Adjustment is easily done by turning the durable steel nut on both legs to achieve proper ride height and use the suspension to its full potential.
• Easy Access with all adjustment screws located on top of the fork leg. Compression damping, rebound damping and preload can all be adjusted while sitting on the bike. This makes it easy to adjust the suspension and have it perform just the way you want it.
•Hydraulic Bottoming Prevention – Like a pillow to prevent the fork from bottoming out suddenly, the hydraulic end stop offers secondary compression damping to smooth out the ride.
•High-strength 35mm aluminum cartridge body is lightweight and maximizes heat dissipation to ensure consistent damping.
•Large volume cartridge holds more oil resulting in cooler operating temperatures, consistent damping and longer life.
•Chrome-plated steel piston rod prevents wear and offers maximum strength and durability resulting in smooth action.
•Includes custom spring selected for your weight and riding style.
•Damping set up for fully-loaded F850GS or GSA right out-of-the-box.
Touratech also has replacement spring kits for your front forks
So if you are unhappy with how soft the F850 front end feel with your riding style, their are a couple of options now available to fix the feel.
