beemerguru
Member
I've installed over 20 Stebel airhorns on mostly BMW sport bike and G/S restorations and rebuilds. From a performance perspective, you can't ask for a better life saving upgrade to a motorcycle. Easy to install and it flat out works to keep the cages from crushing you.
BUT
The physical design is not able to handle the jarring that occurs from the motorcycle suspension. So far, 10 of the Stebels have failed. The plastic section that is actually the horn will separate from the metal compressor and slide down rendering it useless. The horn section is held on by a single plastic loop that snaps at the top to the compressor outlet. The rest is a friction fit that surrounds the compressor. Over time - about 5k miles of street, not off road riding - the plastic loop vibrates and loses its form enough so it cannot retain a purchase. Same for the rest of the plastic,,it expands with vibration.
Then the entire plastic section slides down and the horn can't work.
I just got back from a 5K mile trip and this one failed at 3,5K miles.
I've started using Crazy Glue or Gorilla glue on new units to try and stop this failure from starting. So far 2 units have 3K+ miles and are still holding. Wish I had used the glue on my own unit!
I asked Stebel to go back to their design and improve it to solve this problem..no response yet.
Greg Hutchinson
BUT
Greg Hutchinson
